I have a Toshiba 3220 copier that I am trying to hold on to. The copies are printing, but you can blow the toner right off the paper. I did some research on the internet and found that it may be out of developer. I have tried to find the developer bottle to see if its empty but cant find it. If someone has a manual for this model it will be great! Any suggestions?
Where is the developer bottle On Tosiba 3220
Tags: None
Re: Where is the developer bottle On Tosiba 3220
The developer unit is attached to the PCU, if I remember correctly.
Having said that, your dev is fine, ya fuser has probably had it.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison -
tkjazz
No it is not gritty, is just smooth toner that you can acutally blow right off the paper. I dont know what a fixing issue is, but I am looking at replacing the fuser. Do I need a fuser unit assembly, a heat lamp or a bulb. What should I be looking for?Comment
