Help with Toshiba estudio 3510 scan to email
  • Chris Nolan
    • Sep 2025
    I need help !!! second day trying to get this to work with no luck.
    The toshiba copier is connected to an airport extreme
    The computer is connected to the airport extreme
    I have a gmail account.
    I have set the DNS server and the smtp client up in the top access browser utility.
    any help would be greatly appreciated
    Here is my current config:
    smtp client
    Enable SMTP Client Enable
    Enable SSL Accept all certificates without CA
    SSL/TLS STARTTLS
    SMTP Server Address smtp.gmail.com
    POP Before SMTP Disable
    Authentication Auto
    Login Name ****@gmail.com
    Maximum Email / InternetFax Size 30 MB
    Port Number 587
  • Mr_Fixit
    • Sep 2012
    • 36
    Re: Help with Toshiba estudio 3510 scan to email
    What errors are you getting when you try to scan to email?
    • Chris Nolan
      Email Failed
      • Mr_Fixit
        • Sep 2012
        • 36
        Check the logs either in the machine or through Top Access there will be a error code that can further help troubleshooting this problem.
        • emujo
          • Jun 2009
          • 3009
          Gmail requires ssl over smtp, and uses port 465 (default I think).
          SMTP.GMAIL.COM
          SSL over TLS port 465
          account name and password
          IF the above settings don't work, try to telnet port 465 to ensure customer isn't blocking anything. Emujo
          • didi2005
            • May 2011
            • 401
            Incoming Mail (POP3) Server - requires SSL: pop.gmail.com
            Use SSL: Yes
            Port: 995
            Outgoing Mail (SMTP) Server - requires TLS2 or SSL: smtp.gmail.com
            Use Authentication: Yes
            Port for TLS/STARTTLS: 587
            Port for SSL: 465
            • Chris Nolan
              I tried both setting above and I am still getting the "Failed to send email" message when I try to scan to email. What other settings should I try??
                • 8355
                In Top Access under the email Tab, under from Address, have you entered the authenticated Gmail address that you created in your first thread?
                Under your credentials, how your entered a Password?
                For Primary DNS Server address, did you try 8.8.8.8 ?
                Is your copier at V355 firmware?
                • emujo
                  • Jun 2009
                  • 3009
                  Did you atempt to telnet the gmail server...many IT reps will block the required ports to prevent hackers. emujo
                  • Chris Nolan
                    I am not sure how to telnet. Could you advise??
                    • didi2005
                      • May 2011
                      • 401
                      • TheOwl
                        • Nov 2008
                        • 1732
                        Could you please go to the machine and press the following keys:
                        1. Job Status
                        2. Log
                        3. Scan
                        You should now see an error code against the attempted scans, so can you please tell us what that error code is?
