help!!! 'broken registration'
  • museumfriends
    hi everyone,
    i too have the same problem - after overriding the system yesterday with *13 to get past the passwords, this morning i couldn't use the new department code passwords i had set on copier.
    i used *13 again to try and go through and reset all passwords, and now i have 'broken registration'.... this doesn't sound good!?
    i am viewing a previous post about this from acetler, and the link to the copierprofessionals pdf is broken...
    help!!
    i don't think there are any problems (unless i have caused them) because the copier worked fine yesterday when we overrode the codes.
    HELP!!!
  • tsbservice
    Field tech
    • 8035
    Do 02 and select code based on your country region.
