Toshiba Fax board
  • jltwitch
    • Jul 2010
    • 29
    Toshiba Fax board
    Will a fax board from an ebidge 3 machine (es4520c) work in a ebridge X machine (Es3540c)?
  • Mr_Fixit
    • Sep 2012
    • 36
    Re: Toshiba Fax board
    Both those models use GD-1250 and GD-1260 (2nd line) fax boards, so should be ok.
    • jltwitch
      • Jul 2010
      • 29
      the ones for the 40 series have the NX after them, and from what i am hearing they have a new one for the 40 series NXF
      • Mr_Fixit
        • Sep 2012
        • 36
        Sorry just going by the manual but did notice the difference now in the regions, I get my machines delivered set up so guess I should not have given you advice, I'd suspect they are using different suffixes for regions but I'll bow down to someone who knows what they're talking about
          • 8197
          I believe it will work but the connections that attach the board to the copier do not line up properly. If you do not mind using some twist ties, you should be OK. Try it in the shop for a few days before you put the MFP in the field.
          • emujo
            • Jun 2009
            • 3009
            Toshiba's tech site (FYI) has a cross referance list that goes by model, or accessory..That would be my choice to see if it will work. Emujo
            • arnh79
              • 468
              We have three machines in the field with the earlier fax model on the color EBX series. We haven't had any issues and they've been out there for 6 months or more.
              Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
