Transfer Belt blade falling off - e2830c
  • arnh79
    • 468
    Anybody else have this issue? In the last two months we've had several e2830c series machines code out because the transfer belt cleaner assembly has fallen off. We've tried replacing the blade, belt, cleaner assembly, and TBU. Nothing seems to work. After a few thousand copies the blade unit pops away from the belt. Around the same time we started using Katun toner instead of Toshiba - we're starting to think that's the problem, but I'm just wondering if anyone has had similar experiences?
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • Mr_Fixit
    • Sep 2012
    • 36
    Re: Transfer Belt blade falling off - e2830c
    The white guide on the transfer belt assy that the cleaning blade assy clips into was modified June 2009, if your machines are older than that replace the guide with 6LJ03322000
