Toshiba E-Studio 550 GL1020 Controller Issues
  • Tim C
    • 167
    I have this Problem with a Toshiba E-Studio 550.. "Starting Controller Please Wait". Wont come out of wait. Copies fine, Wont print.
    I have read it is most likley the 20gb HD causing the failure.
    I need help in reinstalling the new hard drive and system software.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Check your pm's.
    • MUMMIM
      • Jan 2008
      • 125
      hi Tim C
      i think it wrong OS, you must update OS and recovery for GL 1020.
      • mhmsaqer
        field Supervisor
        • Jun 2007
        • 83
        Dear sir,
        try to make an image for your HDD in order to use it in the next times.
        I've a master copy made by ACRONICS TRUE IMAGE which i use it to make copies on demand.
        good luck.
        Be happy for a moment - this moment is your life.
        Omar Khayyam
        • Tim C
          • 167
          Thanks for all your suggestions, All is good. New hard drive and software installation took care of the problem
          Thanks to Mr Spock for his direction
          • softballfreak
            the HDD is one problem BUT!!!!
            The HDD after you replace ,it pending if you have one preloaded with the software,if not you wil have to partation the hdd with the partation CD and then load the software with the CD using and extrenal CD drive i have the cd's let me know if you need a copy or you can get it from our site.don't forget it is and iso file if you download it email me if you need more info hope this helps
            also we have seen this problem also caused by the ram chips....
            • Rajah
              Hi I also am having this problem i have a new hdd to install, but i'm unsure of what to do. I have a recovery disk. do i just put in the hdd and install or do i need to do a special software?
              • Mr Spock
                • Aug 2006
                • 2064
                Install the had drive then run the partition cd when that is done run the recovery cd.
                • Accentcp
                  Old Tech
                  • May 2008
                  • 14
                  I need a copy of the software to replace a bad hdd in a gl-1020 can you help.I work primarily on Minolta (23 yrs) I have a client
                  with a IM6530 version of the e studio 650. He has dumped his HDD
                  • ziborg
                    Problem Estudio-35.
                    I have this Problem with a Toshiba E-Studio 35.. "Starting Controller Please Wait". Wont come out of wait. Copies fine, Wont print.
                    I have read it is most likley the 40gb HD causing the failure.
                    Please Mr. Spock, provide me this GL1020 soft. (NT system)
                    • larrylum
                      Controller Starting...Please Wait
                      I'm having the same problem with my Estudio-810. Can someone point me to the Recovery CD?
                      Thanks in advance
                      • Humedss
                        e35
                        E35 use controllers GA1020 and GL1010, the GL hangs from the lower back and the GA is inside up higher on the back left, the cable plugs in on the left for network. When you determine which one you have, repost. The GL1010 uses the same image as the GL1020 posted earlier and uses any standard computer HDD.
                        • aalex_bom
                          • Jan 2008
                          • 214
                          I Think 1020 And 1010 They Have Software Not Same
                          • Humedss
                            Ok
                            I am experienced on this product.
                            • roghaj
                              I'm new here, FIRST POST EVER for me. Easy one I hope.
                              I was told to check if my 550 has a GL-1020 or a GA-1140 by counting the number of tabs when I push the PRINTER/NETWORK button. I get the
                              "Starting Controller Please Wait" message, but never loads. How do I tell which controller I have? Once I figure that out, I am going to need to need more help I'm sure.
                              Thanks for any help you can offer.
                              -Roger
