eStudio 2330c Developer
+ More Options
Posts
  • Solan
    • Aug 2025
    Hey everyone. I've inherited a e-Studio 2330c from a previous employee. I'm really not a tech but I am very capable.
    It looks like it needs some preventative maintenance and I can't find a "how to guide" to walk me through the following:
    - Refill the developer. LCD screen reads time for "Preventative Maintenance code: 0080".
    - Reset the error codes for toner levels. I've replaced the black toner but the display still reads "toner near empty: black".
    Also, if anyone could steer me towards a good reference manual I would appreciate it.
    Thanks,
    Solan
  • Gregg
    Re: eStudio 2330c Developer
    I would call a service company to handle this machine, too many Idiosyncrasies that would cause more problems than what its worth.
    The P.M. counter can be reset, but generally it should be looked at.
    Im sure someone will chime in with a service manual for sale, but like I mentioned, these machines need experienced service or you'll go broke chasing non descriptive image quality errors.
    Good Luck
    • Solan
      Gregg,
      Thanks for your reply however calling a tech is not an option. I have downloaded a 1384 page service manual for this unit but I haven't been able to locate the section on the developer. Does anyone know where I might find it.
      I'm thinking about buying this kit: Toshiba E STUDIO 2330C Black Developer Kit, Genuine (G0691) any thoughts?
      Thanks,
      Solan
      • sagar4
        • Dec 2012
        • 127
        Solan,
        You can buy that kit or just reset counter in pm support mode. If copy quality is good I would just reset the black since I have seen them last 3 times as long. Hope this helps.
        "Broken again"
        • Solan
          Thanks Sagar. I'll do that.
          Solan
          • canonbundy
            • Jun 2012
            • 607
            Thanks,
            Solan
            The Code will be 0008 and I suggest you follow Gregg's advice and consult a Tech otherwise you could have a really big boat anchor.
