Toshiba 2500c Blank Copies, Prints fine...
  • 300EVIL
    • 38
    Hey Everyone!
    I have a 2500c that's acting up. Printing the meter count or calibration test chart comes out fine but copies off the glass come out completely blank.
    I checked and replaced both RAM sticks as well as confirmed they were in the right slot. I also re-seated the ribbon cable going to the scanner.
    Is main board replacement the last step? Anything else I should try first?
    Thanks!
    Adam
  • didi2005
    • May 2011
    • 401
    Re: Toshiba 2500c Blank Copies, Prints fine...
    Did u try scan to fileshare/efiling using radf/feeder and pattern glass, whether the image is totally black or not?
    Looks like scanner problem. If RADF ok, but glass ng, then it might be the cable problem....
    • canonbundy
      • Jun 2012
      • 607
      Originally posted by 300EVIL
      Hey Everyone!
      Thanks!
      Adam
      Your problem lies with the Imaging PCB (located behind the SYS PCB) 9 times out of 10 physically removing the IMG PCB from the LGC PCB cleaning the contacts and reseating will rectify your Blank Copy problem.
      • 300EVIL
        • 38
        Spot On! That's exactly what it was. Works like a champ now.
        Thanks a lot for the help!
        E
        • canonbundy
          • Jun 2012
          • 607
          E
          Happy to help E
