Toshiba eStudio 2551c print density adjustment
  • Techead42
    • Mar 2008
    • 32
    We sold a eStudio 2551c to a customer who needs the print density adjusted extremely dark; copy quality is fine from the glass, but the customer is comparing their print quality from their PC's to an older Toshiba model (eStudio 230) and finding it lacking. Does anyone have any information on how to tweak the print density so that it equals copy quality?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Toshiba eStudio 2551c print density adjustment
    Paul@justmanuals.com
    • canonbundy
      • Jun 2012
      • 607
      Best you don't tweek anything, clean slit glasses, check the PM Life of the Dev, and Drum Units and replace if necessary (9+Start > pow on > 103) perform recal (0+5 > pow on > 396 > 4719 > 4 > FAX > 1642 > 70 Fax > 1008 as a last resort remove Laser Unit & clean the inside of the slit glasses or what Paul suggested.
        • 8146
        How many clicks are on the copier? Did you try a different Toshiba print driver like PSL3. What firmware version is your copier at?
