I have an Toshiba E 353,E453 and E352 all three machines work but, the right side door(T/S corona unit) will not stay close on it own.If I close the duplex unit the machine works fine .All hinges and latches look OK on the right door.Is there a trick to making the door stay close?
Toshiba E 352 right side door
Re: Toshiba E 352 right side door
I have an Toshiba E 353,E453 and E352 all three machines work but, the right side door(T/S corona unit) will not stay close on it own.If I close the duplex unit the machine works fine .All hinges and latches look OK on the right door.Is there a trick to making the door stay close?"Broken again"
