hi there... need your help. i have toshiba e studio 2500c. magenta have no printout. when i do calibration, yellow, cyan and black ok. but magenta blank. here i refer the sample printout for the calibration. hope someone can help me. i change a drum unit for magenta 1 set but still same. hope someone can guide me to settle this problem.
toshiba es 2500C no printout magenta
Re: toshiba es 2500C no printout magenta
Yes I would also check to see if theres developer in the unit. Normally you would get a code but there is that rare occassion you dont. Also I would check to make sure the drum is in right and rotating."Broken again"Comment
[QUOTE=sagar4;335552]Yes I would also check to see if theres developer in the unit. Normally you would get a code but there is that rare occassion you dont. Also I would check to make sure the drum is in right and rotating.[/QUOTE
i change new dv magenta. Also new drum. But still same. Now machine appear error code ce40. I follow all the instruction for troubleshoot. But cant solve.Comment
Cliff.Comment
