Scan to Email Using Gmail SMTP -2330C
  • Flavio21
    • Aug 2025
    Hey.
    I need help configuring the SMTP Toshiba 2330c.
    I searched the forum and found several answers, but none with you for the work ..
    I leave here the data are accurate ..
    SMTP Client
    Enable SMTP Client -
    Enable SSL -
    SSL/TLS -
    SMTP Server Address -
    POP Before SMTP -
    Authentication -
    Login Name -
    Password -
    Maximum Email / InternetFax Size(2-100) -
    Port Number -
    SMTP Client Connection Timeout(1-180) -
    SMTP Server
    Enable SMTP Server -
    Port Number -
    Email Address -
    Enable OffRamp Gateway -
    OffRamp Security -
    OffRamp Print -
    Regards
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Scan to Email Using Gmail SMTP -2330C
    first set up an account for the machine to use (copier@gmail.com) or something like that
    second login to this account via the web and turn on the relay option in the settings.
    then go to help and look for outlook express setup use this data to populate the fields under the smtp client.
    • seb197
      French Tech
      • Feb 2013
      • 10
      SMTP Client
      Enable SMTP Client - activer
      Enable SSL - activer
      SSL/TLS - STARTTLS
      SMTP Server Address - smtp.gmail.com
      POP Before SMTP - desactiver
      Authentication - auto
      Login Name - login gmail
      Password - pass gmail
      Port Number -587
      reseau:
      dns
      8.8.8.8
      8.8.4.4
      Admin
      email: mail gmail
      I can make a copy?
