E studio 35 - Solid black copys
  • WilliamTucker
    • Jul 2012
    • 38
    I worked on an E studio 35 for a friend today and changed thier developer, drum and cleaning blade. I also cleaned it HARD, everything! This machine is ancient and has been used to death. I then went to test it out and it gave me solid black copys from top to bottom. it does this on prints and copys. the cleaning blade works perfectly when i hand rotate it. the main charger is in near new condition as well as the discharge corona and the other one.
    As far as I know all the components i rebuilt were reassembled correctly. any light that can be shed on the situation would be much appreciated.
  • savi0r
    • Sep 2010
    • 363
    Re: E studio 35 - Solid black copys
    My guess is that this is still a main charger problem.
    • viorel
      • Mar 2013
      • 8
      First check that the mass of the cylinder to be in perfect condition. Should be a tab inside the cylinder must make weight. There may be problem. Be the problem and charger.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • WilliamTucker
          • Jul 2012
          • 38
          Really funny. I was aware that someone else had been shoving components into the copier while i was smoking. but i guess during that time they bent the drum ground back so far it was touching the charger. this made the copy's solid black as well as made the interface go solid blue during the charge. very ridiculous.
          • savi0r
            • Sep 2010
            • 363
            Conclusion : you need to quit smoking. )
            • WilliamTucker
              • Jul 2012
              • 38
              Lol yes I do.
              • tecnicoariel
                • Apr 2013
                • 6
                Hi, check or change the grid load.
                Toshiba 4408672480
                • knightfall
                  • Jul 2006
                  • 633
                  Toshiba 4408672480
                  he solved it already
                  Get your facts first, and then you can distort them as much as you please.
