toshiba e-studio 650 copy output is rough
  • lacsouz
    • Sep 2012
    • 9
    Good Day Please help,
    My problem in my machine is when i use it the output of the paper is very rough, it look like a sand paper,
    i believed that was the developer material.
    I,ve change the following and nothing's happen
    1. developing assembly
    2. primary corona
    3. drum assembly
    4. transfer belt assembly.
    best regards,
    jhun
  • JustManuals
    • Jan 2006
    • 9838
    Re: toshiba e-studio 650 copy output is rough
    Paul@justmanuals.com
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Did you reset the counters?
      Did you run developer setup?
      Is the developer unit turning?
      Is the machine adding toner correctly?
      Have you checked the drum ground?
      • lacsouz
        • Sep 2012
        • 9
        @mr, spock,
        thanks to your reply,
        already did all of those, still nothings happend
        reset the counter
        run developer
        check drum grounds
        this is the latest i did.
        changing the HVT
        1st 1-5 copies is good,
        when multiple copies ex. 10copies and up, the problem occur.
        • Mr Spock
          • Aug 2006
          • 2064
          are you using generic toner or developer?
          what number was 05-200 at when you finished?
          • lacsouz
            • Sep 2012
            • 9
            yes im using generic toner, i also did this (05-200).
            • Toshiba911
              • 24
              Did you change 08 - 401 to 0
              • lacsouz
                • Sep 2012
                • 9
                yes i change it, still the same...
                • canonbundy
                  • Jun 2012
                  • 607
                  2. primary corona
                  3. drum assembly
                  best regards,
                  jhun
                  What can happen inside the Toner Hopper is the Face of the Toner Sensor does not get cleaned properly and assumes there is plenty of toner inside the Hopper which in turns decides it does not need to supply the Developer Unit any, therfore the Dev gradually is depleted of Toner giving a grey and sandy like feel to the print surface. Inside the Hopper is a Toner Sensor Wiper which is made of a thin 'rubber' material and tends to curl over time and therefore cannot wipe the surface properly, the short fix - remove and clean the Sensor, retone the Dev - perform a Dev Initialization 05-200.
                  The correct way is to replace the Sensor Wiper and the Developer then 05-200.
                  • michaelc
                    Field Tech
                    • Mar 2011
                    • 590
                    Athing which is ignored by to many at my place is the actual toner filter. Change it, and also if you have the funds the ozone filters. just my 12 pence.
                    It didn't say that I couldn't do it in the manual.
