Toshiba E Studio 16
  • seal
    • Jul 2025
    Toshiba E Studio 16
    I've purchased a second hand Toshiba eStudio 16. Everything seems to be in working order. However, when I try to set changes via its IP address, I cant because I dont know the admin password. Is there a way to either get the admin password or reset the machine to factory default? Your responses would be greatly aprreciated. Thanks.
  • Sbarro
    • 176
    Web access admin password is :"sysadm"
    You don't need any password to change IP directly from the panel.
    Maybe you have department codes active ?
    Can you get a copy without password ?
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
