Toshiba 455 APS doesn't work
  • gideon
    • 283
    When copy mix legal and letter APS doesn't work, always go to legal only. When only letter or legal fed in ADF will copy to the correct tray. All setting on user are ok, setting on 08-604 is for APS, is there any other setting I can try? Thanks.
  • arnh79
    • 469
    Re: Toshiba 455 APS doesn't work
    Toshiba's don't have mixed original copying on by default. It's a different setting then APS.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • sdrawkcab
      Confused & Bewildered
      • Jun 2009
      • 317
      08-618 set to 1
      Some days, it's just not worth chewing through the restraints
      • gideon
        • 283
        Originally posted by sdrawkcab
        08-618 set to 1
        You are right and absolutely not wrong, it works, thanks.
