toner empty
  • longinus
    toner empty
    gentlemen,
    I have problem eStudio 18. always toner empty showed.and machine cannot operate. I have change new original toner, logic board, Ic Chip of the machine, and cable that from ic chip goes to board, still toner empty is there. if 08-203 set as 1 machine can work but counter doesn't count up. any body can help? please
    thank you
  • aalex_bom
    • Jan 2008
    • 214
    Re: toner empty
    Gears on developer broken , because gears is small and weak. Checking them
