E-Studio 352
  • mtuncel
    • Apr 2012
    • 14
    [Error Code] E-Studio 352
    Hi
    We use genuine toner. However, "Toner not recognized" error writing on the screen. Toner engine cleaned. But the error keeps on giving.
    Do you have any idea?
    thanks
    Good work.
  • JustManuals
    • Jan 2006
    • 9838
    Re: E-Studio 352
    Paul@justmanuals.com
    • aalex_bom
      • Jan 2008
      • 214
      Re: E-Studio 352
      check toner and cover, Switch.
      es452-spl-toner.pdf
      good luck to you
      • Burnout
        Re: E-Studio 352
        the toner sensor actuator is well...touchy, and cracks easily and often.the cartridges also have a habit of deforming at the ring the toner sensor rolls on.both can usually be adjusted out, assuming the toner is correct for your area (no idea what ya'll use there). I think you might be able to turn that message off as wellmaybe 08-794 or 972.Pixel counters also give strange probs might check those as well 08-1500s good luck!
        • canonbundy
          • Jun 2012
          • 607
          Re: E-Studio 352
          Originally posted by mtuncel
          Hi
          thanks
          Good work.
          Check if toner bottle turns - if not replace the the Toner Coupling Drive Gear - 6LA68906000.
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Re: E-Studio 352
            The micro switch which the toner bottle is designed to hit can go on these rarely, I have changed maybe 3-4 in 10 years.
            It didn't say that I couldn't do it in the manual.
