e studio 3510 clear or dark
  • ESTANISLAOWENENTON
    • Aug 2025
    HELLO
    I have this problem
    I get the impression clear, but the copy is full
    do printer calibration, and nothing
    performed 395.396, 1008, 4719 nothing
    is oscurese too
    'll upload attachments
    thanks for your help
  • canonbundy
    • Jun 2012
    • 607
    Re: e studio 3510 clear or dark
    Originally posted by ESTANISLAOWENENTON
    HELLO
    I have this problem
    is oscurese too
    Not sure about translation but Calibration should be 395>396>4719>4FAX>1642>70FAX>1008.
      if
      I did so
      but nothing
      thanks
      • canonbundy
        • Jun 2012
        • 607
        if
        I did so
        but nothing
        thanks
        When you say "nothing" do you mean the machine won't Calibrate?
        Check 08-556 & 557 are set to 1. If set to 0 the machine cannot perform the IQC. (this is normally turned off if the Tech can't fix the problem).
          tomorrow I will
          thanks
