Toshiba e studio 450 light copy
  • mido
    • Nov 2011
    • 176
    Hi all
    I have a problem in e studio 450, the copy is very light, no toner only on developer,
    I put toner by hand in the in the developer, then the copy becomes perfect, normal copy.
    can you tell me the adjustments that let the toner drop automatically, or the reason of this problem,
    regards
  • emujo
    • Jun 2009
    • 3009
    Re: Toshiba e studio 450 light copy
    If you can manually add toner and the CQ gets better, then the problem is in the toner hopper section..pull the hopper and look at the gear that turns the bottle, this is a weak spot on this series. Emujo
    • mido
      • Nov 2011
      • 176
      thank you for your reply
      I will check up tomorrow.
      regards
