toshiba e-studio 452 error c10
  • smiley
    • Aug 2008
    • 615
    good day guys. i need some help on this just happen every time i copy on legal 13" paper size. in every cassette even in bypass tray but on letter size it works fine i replace the dev. unit, fixing unit, registration clutch and the drive motor but still it gives the same error. please help guys. thanks. im sorry the error is c010.
    there is no glory without sacrifice
  • canonbundy
    • Jun 2012
    • 607
    Re: toshiba e-studio 452 error c10
    Error C010 refers to a load on the Main Drive Motor, never had to change a motor yet, if the Dev & Fuser Units turn freely then I would suspect the Drive Train Gear Assy has either worn gears or the Gear Shafts are gummed up - remove each gear & clean and lube the shafts.
    • emujo
      • Jun 2009
      • 3009
      Sounds like the high/low speed clutches are binding. Emujo
      • smiley
        • Aug 2008
        • 615
        thanks for your reply guys. i already remove all gears at the back and clean lubricate the shafts and the gears but still it gives that error only on 13'Lg size. and it runs smooth on letter size.even single copy or multiple copies. where do i can find the high/low speed clutches?
        • emujo
          • Jun 2009
          • 3009
          Item # 22, and 23 on page 2-3 of the service manual. Emujo
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            There were some mods released for the main drive assembly for C010 error codes. There was a new damper etc.
            It didn't say that I couldn't do it in the manual.
            • canonbundy
              • Jun 2012
              • 607
              Ok, another stab in the dark - have you tried changing the paper size to 13" in the other cassette? or swapping feed assy 1 with 2?
              • smiley
                • Aug 2008
                • 615
                sorry for late reply guys. im using 13"lg all cassettes and also i already change feed assy 1 and 2. but still it give that code even on bypass. only just on 13"lg.
