e207 duplex printout problem
  • didi2005
    • May 2011
    • 401
    Any 1 encounter this issue before? Only happen on duplex copy/print on last page...
  • savi0r
    • Sep 2010
    • 363
    Re: e207 duplex printout problem
    On regular copy /prints works fine? What's the counter on the machine? What have you done so far?
    • didi2005
      • May 2011
      • 401
      Simplex copy/print works fine...Counter more than 1 million...I've replaced mag.roller, roll guides, and developer material to solve blur print issue...
      • savi0r
        • Sep 2010
        • 363
        If i were you, first of all i would have cleaned very well the imaging unit. Esspecially the charging unit.Second, cleaned the transfer/separation unit. maybe would have changed the corona wires.Then i would have checked the duplex unit and the adu unit for worn rollers, dust on sensors,etc. In other words, clean the machine inside out. After this, if the problem remains, try stoping the paper in various sections of the copy proces to try to isolate the unit that is causing this.The problem appears on the copy in the exact place, every time?
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          1 million plus on this model, i applaud you. No point in repeating other posts but i had t put that in.
          It didn't say that I couldn't do it in the manual.
          • savi0r
            • Sep 2010
            • 363
            Indeed, on this model, 1 mil is really a achievement.
            • didi2005
              • May 2011
              • 401
              The problem appears on the copy in the exact place...
              Haiz..The machine almost 6 years...users very fussy, equipped with laser eye....
