E Studio 161 F5-02 error code
  • yormets
    • May 2009
    • 336
    I know this is an exposure lamp fault code. However I don't believe it's the lamp. If it is, how in the world does it come out? Is there a hidden thermal fuse somewhere? Anyone seen this before? I know this machine is actually a Sharp copier. An ARM 160. We just don't see these florescent
    lamps go bad. I guess it could happen.
  • savi0r
    • Sep 2010
    • 363
    Re: E Studio 161 F5-02 error code
    I also didn't had bad lamps on these machines. You can test the lamps from the service mode, if i remember correctly.
    • yormets
      • May 2009
      • 336
      How do you enter the service mode on this model? It's a relabled Sharp. Sharp procedure doesn't work because there is no pause key.
      • savi0r
        • Sep 2010
        • 363
        The initial "C" key ->AUTO/TEXT/PHOTO key ->"C" key ->AUTO/TEXT/PHOTO key; sequence must be performed quickly with no more than a second between key strokes.
        What you need is :
        Press 05 -> Start- that's how you enter the main code
        The Subcode you need is:
        03 Copy lamp lighting check
        Good luck.
        • yormets
          • May 2009
          • 336
          I changed the whole lamp assy and it still doesn't light. Must be the main board?
          • savi0r
            • Sep 2010
            • 363
            Have you checked the harness between the lamp unit and the pwb? If so, than your next move, according to the manual is to change the pwb. My advice : if you must really fix this copier, than buy a used toshiba 161 and get the parts from that one. A new lamp unit AND pwb are really expensive.
