Estudio200 Call for service
  • hrichards
    • Aug 2025
    Hey guys, I have search the board here looking for "Call for Service" in the technical area but can't find anything.
    I have an estudio200 that shows on the display Call for service.
    The paperjam, paperout, and a little bucket full of canonballs, light is lit. It has paper, there is no paperjam, and I don't know what the bucket of cannon balls mean, but they are all flashing in unison RED.
    I reset the maintenance counter, so that was not it, and it did just do this, it was working fine and printing for us without an issue.
  • hrichards
    I used Diagnostic Code 400.
    It had code 7 in it.
    • arriva1
      • Apr 2007
      • 66
      You need to hold down clear and 8 buttons at the same time to get error code.
      • leolives
        Here are the codes for 08-400
        Thermistor heater status counter
        0: No error occurrence
        1: C41 1st thermistor or heater error
        when starting W-UP
        2: C41 2nd thermistor or heater error
        when starting W-UP
        3: Reserved
        4: C43 Thermistor error during W-UP
        5: C44 Heater error during W-UP
        6: C43 Thermistor error after ready
        7: C44 Heater error after ready
        8: C45 Heater end thermistor error after
        ready (High temperature)
        9: C44 High temperature heater error
        10: C45 Heater end thermistor error after
        ready (Low temperature)
        Check your thermistors and your heater lamp.
        Hope this helps
        • hrichards
          Thanks Guys. This fixed it again for me.
          I set the 400 diagnostic code to 0 to get it going again. I was a 7 again.
          • Baphomet
            Copier Technician
            • Aug 2008
            • 293
            If the code returned then it means that you most likely need new thermistors. The canon balls simply mean you are out of toner.
            • tsbservice
              Field tech
              • 8042
              It's normal for these when there is Call for Service that paper jam,add paper and add toner symbols flash.Hold down C+8 will display the code and after repairing the problem you are good to go
