l have solution for 5570
  • esam ramadan
    • 199
    we have faced in toshiba digital copier 5570 problem with high tension board
    it come bad quickly and gives black copies the reason is in vertical IC between the two high tensions , you can get it also from high tension board
    in toshiba 4560-2060
  • HASSAN
    • May 2008
    • 43
    HI :Eng esam
    We are oriental for supplies (eng HASSAN ELWASEMY) please coll me Tel # 0233385922-0233389905 .
    Thank you
    • case807
      • Sep 2007
      • 11
      if you want this ic we have it just call 0102687630
