Toshiba es720 toner feed problem
  • irtek
    • Jun 2009
    • 110
    I've got an es720 that is running light from toner depletion. The toner low indication came on and customer kept running without adding toner. The copies started getting light so they changed the toner. The machine would not recover. I disassembled and cleaned the toner sensor and the sub hopper assembly (mostly so I could see how it works. Reassembled and tested. Machine still will not recover. Display say Toner Low and the bottle rotates but the New Toner auger never turns. Thought it might be a bad motor. Swapped another assembly in and same thing. Went into 03 service mode (should have done sooner, still new to Toshibas) and the new toner motor ran fine. Ran it some and cycled machine and the copies were better. Did a couple more times and the copies are toned up but the display still says Toner Low.
    Any ideas on this problem? Thanks for any help on this problem
  • irtek
    • Jun 2009
    • 110
    Re: Toshiba es720 toner feed problem
    Was about due for a PM, so I did the PM and it is running good now.
    • canonbundy
      • Jun 2012
      • 607
      Your previous POST I understand COMPLETELY - however this one will put right back in the same possie!
      The problem is with the SENSOR WIPER in the Hopper!!! .....Over time the Rubber Wiper loses it's ability to clean the Sensor Surface efficiently therefore the Dev Unit gets the incorrect message that 'all is ok' and in turn will not add Toner - the Prints get lighter & eventually produce a 'Grainy feel' on the paper. Replace the Wiper Unit (about $5) ...but ensure the Rubber Wiper is still on the Shaft when you remove it - if not .... empty the Hopper Assy & vacout because it WILL block the Toner flow, replace the Developer & perform Developer Init. > 08-200.
      • irtek
        • Jun 2009
        • 110
        Thanks for the reply. I will do what you recommend. Thanks.
