I have a Toshiba e-Studio 2500C with error C390 I know it's the Cyan but anywhere in particular to look at?? Thanks in advanced.
Toshiba e-Studio 2500C C390 error
Re: Toshiba e-Studio 2500C C390 error
Check the charge electrode is in place. The small plastic lug that holds them in (rear) usually breaks. Just pull the cleaner and see if you can hear it rattling along the top of the charge electrode. If you can't hear/feel it you will need to replace the charger end block and most likely the dev as well.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison -
Ill give it a go thanks mateComment
Paul@justmanuals.comComment
