Need help accessing Toshiba 2830c
  • logoballz
    • Aug 2025
    I recently was given a perfect condition Toshiba 2830c estudio.
    It's in great shape and has brand new toners.
    The problem is that I can't get in to use it
    It's asking for a 5 digit code to use and I don't have one.
    I was able to power up with 8 & 0 pressed and then enter 263
    I used 123456 as an admin pw and it puts me into test mode but then nothing on the screen
    I'd like to be able to go in and assign new 5 digit codes to use or even just do away with that restriction.
    Anyone here have knowledge of how to get in and use this as a copier, fax, scanner?
    I'm downloading the drivers now for printing but am not optimistic that it will let me in once I connect it to my computer.
    Any help would be greatly appreciated.
    Don
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Re: Need help accessing Toshiba 2830c
    Press Counter then Dept Management.
    enter Admin Password
    press Dept Management to enable/disable codes or press Dept Registration to enter a new one.
    Some days, it's just not worth chewing through the restraints
    • Acme
      • Jan 2013
      • 155
      08-8919 will show you the password. Should be blank by default.
      also set 08-8911 to 1 while your in there.
      • logoballz
        Where do I enter this from?
        The test page or just after I startup with 08?
        Thanks for the help
        Don
        • logoballz
          Counter then Dept Management asks for a PW but 123456 doesn't work there
          Don
          • Acme
            • Jan 2013
            • 155
            It should be blank, if not check the 08 I posted and it will show current password
            • logoballz
              SUCCESS!!! Thanks gang!
              Don
