CF20 in Toshiba 351c
  • copyalbania
    • Aug 2009
    • 165
    Hello,
    I have a toshiba 351c ande shows error code CF20.
    I went to 08/824 and showed 1 for yellow and cyan.
    I reset and it shows again error code ......i put new developer yellow and cyan genuine from toshiba, but again CF20.
    I checked 08/820 but the values is 0 for cyan.
    I checked the auto toner sensor it is working also i cleaned it but the same error.
    Can anyone help me??
  • canonbundy
    • Jun 2012
    • 607
    Re: CF20 in Toshiba 351c
    Originally posted by copyalbania
    Hello,
    Clean Patch Detect Sensor (under R/H side of T/fer Belt assy).
    Clean Colour Auto Sensor & remove black plastic cover, blow out (should be light grey in colour) located L/H side of T/fer Unit.
    T/fer Belt ok - not torn?
    2nd T/fer Roller ok?
    Did you perform Dev init for the Colours replaced?
    Did you perform Calibration after All the above?
    • copyalbania
      • Aug 2009
      • 165
      DO you have photo where the : Patch Detect Sensor (under R/H side of T/fer Belt assy) ???
      Also what is the code for Developer Init??
      • emujo
        • Jun 2009
        • 3009
        You know, it might be a good idea to get a service manual for the MFPs you work on....I'm just saying...Emujo
        • copyalbania
          • Aug 2009
          • 165
          I have a service manual and i have searched for it but i did not see the term " Patch Sensor " that is why i have posted for a photo.
