Toshiba e352 has c41 .How....fix..?
  • anh_duongsb
    • 24
    This morning ,I checked toshiba e352 which show me that error c41 .I check all and don't know how to fix this error .Plz help me solve this .Thanks
    email: bloggerviet123@gmail.com
  • toantam
    • 63
    Re: Toshiba e352 has c41 .How....fix..?
    Dear Friend!
    First you have to check therminstor and thermoswitch or you can try to reset error then try to change another fusing unit.
    You can check DC power supply.
    Good luck to you.
    • Mad_Coachman
      • 99
      08-400 start reset to 0 start
      • anh_duongsb
        • 24
        Originally posted by toantam
        Dear Friend!
        Good luck to you.
        I checked them all and checked sys board but it is still the same .Thanks for your advice
        • anh_duongsb
          • 24
          I did but still the same error c41 Thanks for your advice .Hopefully I can solve this problem as soon as possible .
          • bvaldir
            • 17
            • anh_duongsb
              • 24
              I will try and let you know the result .Thanks so much .If any friends
              who need toshiba firmware .Plz contact
              me
              thru bloggerviet123@gmail.com .I will give you for free .
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • anh_duongsb
                  • 24
                  Dear all friends,
                  I changed power board and fuser to another copier .They work well .I can not find which is error for my copier .Plz help me .thanks
                  • vinhsesco
                    • Jun 2009
                    • 30
                    Dear all friends,
                    hello you
                    if you do not reset at all. you can update the latest firmware version 356 will fix all errors. wish you success
                    • anh_duongsb
                      • 24
                      Originally posted by vinhsesco
                      hello youif you do not reset at all. you can update the latest firmware version 356 will fix all errors. wish you success
                      Thanks so much .I will try and let you know the result .Thanks for all replying my post .Wish all the best to you .
                      • anh_duongsb
                        • 24
                        Have You seen this error before? Why you suggest me update e356 and All the board in the copier will fire .Thanks for your best advice .
                        • aalex_bom
                          • Jan 2008
                          • 214
                          Good idea . You can burn your copier. And buy new estudio 856
                          • anh_duongsb
                            • 24
                            Thanks for discussing my topic .Hopefully that e352 copier will be ok .If you know who has been seen this error .Plz suggest the way how to fix it .Thanks
                            • michaelc
                              Field Tech
                              • Mar 2011
                              • 590
                              I punhed he lcd and itgot rid of this code. Screen didnt even dare show anyhting. iT knew i was the bass
                              It didn't say that I couldn't do it in the manual.
