e-Studio 2555c - Annoying Beeping when going to Energy Saver Mode
  • Unknowning_Sysadmin
    When the eStudio 2555c goes into energy saver mode it gives out a loud annoying beeping. Is there a UI or service code way of removing that?
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: e-Studio 2555c - Annoying Beeping when going to Energy Saver Mode
    Can disable all the beeps in the 08 codes, not sure what the code is off the top of my head. You can always change the sleep/power save times.
    It didn't say that I couldn't do it in the manual.
    • Travis06
      Tech.
      • 193
      08 Setting
      Mode
      System User
      interface
      Sound 9281 Sound setting --
      Energy Saving
      Refer to
      content
      s
      0-1 SYS 0: OFF
      1: ON
      <Default value>
      JPD: 0
      Others
      Set 08 mode 9281 to 0
      • Shentao
        Hello everybody,
        I have the e-Studio 2555c, too. Thank you for the code to turn off beep when entering energy saving mode. Could you tell me the service code needed to turn beeps off altogether?
        Thank you very much!
        • chrinico
          Originally posted by Travis06
          08 Setting
          Mode
          System User
          interface
          Energy Saving
          Refer to
          content
          s
          0-1 SYS 0: OFF
          1: ON
          <Default value>
          JPD: 0
          Others
          Do you know the code to turn off the energy saver beep on model 2050c?
