Machine will run copies normally then (all of the sudden) stop running copies and run like it is adding toner. The next copies it shoots out will have a light background. Sounds like a setting is off but I have no idea which one. Any help is greatly appreciated
Toshiba Estudio 350 Bizaar Development (Toner) issue
Re: Toshiba Estudio 350 Bizaar Development (Toner) issue
If it's a ticking sound it could be searching for toner. Unless it's the Dev tank or toner hopper making noise, it just depends on the noise it can be making but I'll check the Dev tank that's located underneath the drum unit unscrew pull it out and rotate the gear located on the back of the Dev tank. Good luck -
Changed the developer... No change...I think it has something to do with the HVPS or Main Board. I am selling them a new machine...Comment
