We have an estudio 256 that says it doesn't recognize toner, but if you go and check the toner level it says full. we have updated the firmware and now are at a total loss. Any help would be greatly appreciated!!
e studio 256 not recognizing toner
Re: e studio 256 not recognizing toner
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
paul@justmanuals.com
Have you tried a different toner cartridge? Genuine Toshiba toner?Comment
There is a little board in the back frame of machine with little springs on it one screw removes it and one connector take it out and blow it out with air and put a little stretch to the spring also you might want to clean the contacts where the springs meet the board with some alcohol then reassemble it should work after you do that 255/355/455 were also known for this problemComment
Riyadh hossain
