ES-2330c control panel problems
  • Hansen88
    • 1079
    Hello, about a month ago the entire panel locked up. It would not respond to any inputs either from the screen or the buttons. We put on a entire different panel and that solved the problem. Now this panel is locking up. I turned machine off/on and started responding again but responds real slow to any inputs.Anyone seen this problem before? Any help I will be grateful for. Thanks
  • canonbundy
    • Jun 2012
    • 607
    Re: ES-2330c control panel problems
    Check braided cable ALL the way for pinched wires, sticky fingers & moisture locking keys down, heavy handed or fingers on the Touchpanel can have the same effect as on the keyboard, reseat or replace RAM for slow op?
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Have you checked/formatted the hard drive. Could try the firmware also and a screen calibration after
      It didn't say that I couldn't do it in the manual.
