Toshiba e5520c dropping network
  • r.hutson@absproducts.com
    hut123
    • Oct 2012
    • 2
    [Misc] Toshiba e5520c dropping network
    I have a Toshiba e5520c droping the network connection. Reboot and connection comes back. Does anyone have any suggestions on what could cause this?
  • Acme
    • Jan 2013
    • 155
    Re: Toshiba e5520c dropping network
    Static IP?
      hut123
      • Oct 2012
      • 2
      Originally posted by Acme
      Static IP?
      Yes it has a static IP.
        • 8215
        Check to make sure your copier firmware is up todate. V331.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          static ip outside of dhcp range? to test next time it happens unplug machine and ping ip. If you have a response then that is the issue. If not check next step
          Manually set the speed of the nic card. I have seen the auto negotiate cause issues with it dropping machine off from time to time.
          • Boogotshot
            • 61
            Try the simple stuff first, have you tried replacing the network cable? Try setting the network speed to 10/100 and make sure the machine is on a static IP address. Sometimes it is the dumbest stuff that trips us up.
            sigpic No! we never do that with the copier.
            • Bicyclerepairman
              • 63
              Initialze the NIC
