Scan to "mapped" drive
    • 8254
    I have a new install on a e347cs and a Win7 Pro PC. The customer wants me to scan to a "mapped" Z drive presumably created by going to Start/ Computer/ Map Network Path.
    I can create a folder on the same PC's C drive and scan to it no problem with the computers credentials.
    Any ideas?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Scan to "mapped" drive
    The mapped drive would have had a UNC path before it became Z:, you can find this path in command prompt if you type net use, the original path name is under Remote. Most devices would be able to scan to a UNC path name.
      • 8254
      You learn something new everyday. Thanks!
      • Boogotshot
        • 61
        If the Z drive is a separate server you may have to provide the login credentials for that server. UNC path should read something like \\Server name\folder
        sigpic No! we never do that with the copier.
