E Studio 2100c booklet finisher throws message "close finisher door" when hooked up to machine.
When I open the Top door or the upper front door cover the message changes indicating the micro switches are probably working ok.
However, when I open the lower front door or the bottom exit door on the left side, there's No change or reaction on control panel screen.
I took off the plastic covers to get access and inspected the door switches. The door sensors were clipped into their correct position and clicked when pushed in and out.
The door switch fingers seemed to be fully contacting the switches when the doors are closed.
Is there anything else I can try like going into the service mode and re-set something?
Thank you,
Dana
Thank you,
Dana
