I have a question regarding the email function of the 2500c copier.
I got the smtp and pop3 info from the customer that I am trying to set this up on, and tried to enter this info in the copier. I don't really know the correct input area that I should be using.
What information should be included in the smtp server, client, and pop3 portion of the topaccess of this machine.
for reference, the machine is on a private network (possibly behind a linksys router using the 192.168.1.1 gateway). NAT should not be an issue. Also, I have the same ISP as the customer, and i can connect my laptop to the network and access my email just fine.
Any Ideas?
in the log, the copier shows that it could not contact the smtp server. wierd huh?
Any Ideas?
