Toshiba e studio 3530c CE20 Error.
  • pcernicky
    • Feb 2010
    • 66
    Copier was due for K drum and dev replacement. After replacing and performing 05-396 (Automatic initialization of image quality control) the error was coming back.
    Did I missed any steps after drum and dev replacement that would cause this?
    Please help...
    The machine was throwing these errors prior replacement.
    Printer Error History:
    Date Time ErrorCode Counter
    01/24/2014 09:40 CE20 00406731
    01/24/2014 09:39 CE20 00406731
    01/24/2014 09:37 CE20 00406731
    01/24/2014 09:32 CA00 00406731
    01/23/2014 17:15 EA10 00406701
    01/23/2014 17:09 E940 00406700
    01/23/2014 17:03 CE20 00406699
    01/23/2014 16:45 CE20 00406699
    01/23/2014 16:22 EA31 00406699
    01/23/2014 16:11 CE20 00406699
    01/23/2014 15:47 EA32 00406699
    01/23/2014 15:17 EA32 00406699
    01/23/2014 15:17 C467 00406699
    01/23/2014 15:16 EA32 00406699
    01/23/2014 15:16 C467 00406699
    01/23/2014 09:11 CE20 00406699
    01/23/2014 09:09 CE20 00406699
    01/22/2014 11:22 CE20 00406699
    01/22/2014 11:20 CE20 00406699
    01/22/2014 09:41 CA00 00406699
    01/22/2014 08:02 EA23 00406699
    01/20/2014 13:02 E3E0 00406472
    01/20/2014 13:01 E190 00406472
    01/20/2014 13:00 E190 00406472
    01/20/2014 10:16 E714 00406344
    01/20/2014 08:57 EA40 00406307
    01/20/2014 08:56 CA00 00406307
    01/17/2014 16:50 E712 00406275
    01/17/2014 16:49 E712 00406273
    01/16/2014 11:26 CA00 00406210
    01/14/2014 20:02 CA00 00406185
    01/14/2014 08:58 CA00 00403315
    01/13/2014 17:15 E010 00403136
    01/13/2014 16:49 E010 00403086
  • arnh79
    • 468
    Re: Toshiba e studio 3530c CE20 Error.
    I would start by cleaning the IQC sensors behind the shutter assembly underneath the transfer belt. Even though there is a shutter they still are prone to toner build up and will throw out IQC codes intermittently.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • Bicyclerepairman
      • 63
      Check that the transfer belt cleaning blade is cleaning belt.
      • stockman123
        • 128
        Please help...
        • ivovb
          • 695
          Off topic.
          Hi pcernicky,
          how did You get rid of C467 - I can see it in you list with trouble codes?
          I have change thermistor of pressure roller, checked lamp - they are ok...
          BR
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
          • Aethanite
            Service Technician
            • Oct 2012
            • 42
