eStudio 3055c, copying from dark green originals...
  • Logged-on
    • Sep 2010
    • 197
    I have a customer who want's to copy (in black and white mode) from dark green originals, but have the copy come out as a black and white copy with no background, is there a simple setting somewhere that will allow the print to be copied without the original's color being copied as well?
  • JustManuals
    • Jan 2006
    • 9838
    Re: eStudio 3055c, copying from dark green originals...
    Game manufacturer's used to print with black type on brown paper to prevent you from copying their docs. I don't think there is a way to bypass this.
    HtH
    Paul@justmanuals.com
    • Logged-on
      • Sep 2010
      • 197
      Thanks for the reply, I know the Intravia's used to use the dark colors to deter techs from copying from the manuals, but even with the analog machines they had auto exposure to compensate for original backgrounds. I am surprised in the day and age of whistles and buzzers, copiers aren't capable of only reproducing the black print on an original.
      • stockman123
        • 128
        there is a certan way you have to calibrated in order if no color wont be right
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          You could try adjusting the cq settings for this one print job but would knock a lot of other cq out in the process. There are a lot of adjustments to in the manual. What have you tired so far? I had a similar problem but with a blue background.
          It didn't say that I couldn't do it in the manual.
