es306 vs es356 question
  • CCS
    • 266
    Are these both the same box just with different speeds?
    Or which is the better box?
  • jim v
    • May 2008
    • 41
    Re: es306 vs es356 question
    They are the same box bout 356 is 5 copies faster.
      • 8197
      Same toner, same developer material. The e356 has a bit lower break even cpc. Both work well having been constantly improved upon since the earlier e355 and e355SE.
      • Boogotshot
        • 61
        Same firmware, same toner, same developer, same copier, different speeds.
        sigpic No! we never do that with the copier.
        • CCS
          • 266
          Thanks,
          Would you say that since the improvements over the 355 version (that I skipped all together) that the newer 356 version is even better now than the older 352/353 series ??? I have alot of the 352/353, 452/453 out that seem to run pretty well.
