Error Code (e010) Tos Es353
  • R. Hunt
    • 23
    Does anyone have the answer to Error Code 010?
    The paper will travel to the registration roller just before the drum and stop causing a jam. (5000 copies) Toshiba ES353
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I would check the fuser and the fuser exit switch along with the paper size is correct. This is a exit switch not being hit jam.
    • tsbservice
      Field tech
      • 8020
      I would also check registration clutch аlong with Spock suggested.
      • R. Hunt
        • 23
        E010 Error code
        The problem was the clutch on the aglining roller came lose from the shaft. Tighten it down and is working fine. Thanks for your input all.
