don't like test color toners in 451C
  • MUMMIM
    • Jan 2008
    • 125
    Hi all ! guide me pls !
    In the 451C machine, i don't like it test color toners any time i tune on power,. because it used show CE40...
    are there some the codes for lock that procedure? or lock all color function on 451c? the machine don't show any things when it haven't mount color toners, needn't use color function continuos, only use black function
    thanks .
  • JustManuals
    • Jan 2006
    • 9838
    Re: don't like test color toners in 451C
    http://www.justmanuals.com
    Paul@justmanuals.com
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      There are and it took me over an hour to test and check the codes for a big customer. To get the colour part of the machine disabled. I did it to get the machine going til i got with the parts to fix the fault. I would check the machine out first though. Image reg works from sensors, IQC from the sensor under the tr belt next to the boobies.
      It didn't say that I couldn't do it in the manual.
      • arnh79
        • 468
        Boobies?
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • stockman123
          • 128
          sniffing toner again?
          • MUMMIM
            • Jan 2008
            • 125
            i sure, that can be done by some code , because i have a e3511 it needn't mount colour toner but use only black toner. i ask the supplier for the next machine and he said : " you give me the NVRam on sysboard, i overwrite the program and you can use it for any e3511 only black tone" . i was done.
            how about your thinkings?
            • jayschrodter
              • Dec 2012
              • 36
              Just set 08-556 / 557 to 0 then if you don't want anyone else printing anything in color set as department code
