Toshiba 451c HDD firmware
  • gideon
    • 283
    I need to replace the hard drive - where can I get the firmware? I'm not a Toshiba authorize, I have the manual and work on this model for a long time but never had to replace the HDD.
    Error is " HDD not mount"
    can't initalize with clear-3, can't access any simulation.
  • stockman123
    • 128
    Re: Toshiba 451c HDD firmware
    I got that firmware email me at stockman123@hushmail.com if you haven't found it yet
    • gideon
      • 283
      I have the 28_451c folder and the menutusb.o file in the root, the mentusb.o has 0 files in it, is it good with 0 files?
      If you have a mentusb.o file with realy some files in it please send it to me at gideon@countrycopy.com
      • canonbundy
        • Jun 2012
        • 607
        Helloooo! Someone has sent you the right stuff - Make sure the USB KEY is formatted before loading the Folder - Mentusb is a 6 kb file & should be in the Root Dir, copied from the Folder also in the Root, insert Key & power on holding 4+9 keys down to activate F/ware download, when (& if) the Selection Screen displays - then highlight only 1 & 2 (SYS & HDD) > Start, if download 'COMPLETED' displays after about 10 -15 mins then Engine & Scanner files etc may be downloaded.
        Power off, hold 0+8 > Power On > enter 947 > Start > 693 > Start.
        • stockman123
          • 128
          you shouldn't have to select any thing just start it will check and install what it needs on it's own after the download shut down machine do o8 1119 enter and 08 947 enter and your finished otherwise you will get a error
