Toshiba e-studio 2820c time for periodic maintenance
  • awad
    • Mar 2010
    • 21
    I have Toshiba e-studio 2820c, I got message "time for periodic maintenance".
    How to reset it
    Please advice
    Regards
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    Re: Toshiba e-studio 2820c time for periodic maintenance
    Power up holding down print and 6 this will display pm support mode required end of life parts will be highlighted replace required and clear each counter etc
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • stockman123
        • 128
        How to reset it
        Please advice
        Regards
        08 power on key in 9891 enter one shut off and back on
        • Riyadh hossain
          by pressing 0 and 8 then power on. press 251 then start then clear/ cancel then interrupt. your machine is ok
          • stockman123
            • 128
            hold down 08 power on key in 9891 enter or start or print then key in 0 then print or start this will turn off all maintance counters we shut them off because if there on a mainance contract we do it as needed to get the most life we can out of the components
            • blackdog
              • Jun 2012
              • 211
              Does this apply to a es355? I don't have a handbook. Thanks
              • Riyadh hossain
                yes same
                • stockman123
                  • 128
                  yes for most model machines
                  • blackdog
                    • Jun 2012
                    • 211
                    Thank You
                    Springfield, MA?
                    • stockman123
                      • 128
                      this is the way to do it otherwise you get call for ridiculous tasks that don't need to be done so do this procedure
                      • dbrownlee
                        • Sep 2005
                        • 197
                        Stockman, any luck with that check?
                        GO TIGERS!!
