3500c df problem
  • poekeypop
    • Feb 2014
    • 16
    [Error Code] 3500c df problem
    posted this a few weeks ago, more info. place orig in df, press copy, runs through fine,but shows jam in df. will not clear unless u turn off/on machine. 03 7,8 a-h e-g all ck ok until u open cover, then dont. i changed out reg sensor(ordered new) still goofy???? shows a e712, have done/ ck all but df pwb. i no its slappin me in the face, anything i am missing? those boards go bad? i have seen on other brands b4(sharp,kodak) anyone, anyone, bueller? lol
  • canonbundy
    • Jun 2012
    • 607
    Re: 3500c df problem
    When you say "copy runs through fine" do you mean a Copy of the ORIGINAL is produced and then shows RADF jam because the Original does not exit or the Original EXITS the RADF and THEN shows the jam?
    Just on spec.....if the Original jams before exit - then check for folded back Mylar Guide Strips in the exit area.
    If the original exits then shows the jam - check for sticking Flag and/or replace the Exit Sensor.
    • poekeypop
      • Feb 2014
      • 16
      The copy runs threw fine,exits out to finisher, original passes threw doc feeder,then shows jam. I am gonna tear into to see if any flags hung up,lazy,sticky. I checked with flash lite, ran cardstock threw manually. Doesn't make sense. This is a group of machine I picked up,4 sharp,1 toshiba , lol, Murphy's law
