When I want to make a copy ,machine ask me for departmental code, How can I disable departmental code? and how can I set departmental code as wish my own password? with best regard for knowing
toshiba e studio 453 departmental code
Tags: None
Re: toshiba e studio 453 departmental code
go to admin from control panel and then usersComment
Hello, I have service manual, but there is no access to the "service mode". In my work I have not Toshiba copier and I need how to access the "service mode" and what to do if:
1.) I change photoconductor drum
2.) developing unit
(reseting the pages, clearing maintenance count, mixing the developer).
Or what kind of manual (except service manual - this manual I have) I need to download?? (operation manual)???Comment
2.) developing unit
2.) developing unit
Easiest way to reset counts is to holding 0+6 and power till machine beeps while powering on, when it is fully booted up press 2 and then start. A menu pops up with all the counters that can be reset.
The counters can be reset in the 08 or 05 mode(forget which) with an individual code for each part but the 06 route is much faster.Comment
2.) developing unit
6+S power ON machine to enter PM support mode, reset the replaced parts counter.
Normally developer no need reset, because after replace u need to perform auto toner adjustment, it will reset automatically...Comment
I am sorry, but exists two different service manuals:
1.) Service manual
2.) Service handbook
And in service handbook is "service mode".toshiba-service handbook.JPGToshiba-service manual.JPGComment
go user function
counters
dept managment password should be 123456
disable dept code
if you want to add dept code
same process execpt go to dept registration, find empty box and add your name and code.Comment
