Im Having A Prblem With A E Studio 350 It Has An F105 Code I Now Its A Hdd Problem I Replaced The Hdd With A New One But Now The Machine Will Not Boot Up I Got The Hdd In A Frys And Now I Realize The Hdd Carries The Boot Up Info Is There Any Way Of Getting The Info From One Hdd To The Other In Order To Make The Machine Work
E Studio 350
you need to format/initialize, and reload all firmware, if old firmware you need to upgrade gradually for example from 250 to 321 you have to update to 300 then 320 then 321Im Having A Prblem With A E Studio 350 It Has An F105 Code I Now Its A Hdd Problem I Replaced The Hdd With A New One But Now The Machine Will Not Boot Up I Got The Hdd In A Frys And Now I Realize The Hdd Carries The Boot Up Info Is There Any Way Of Getting The Info From One Hdd To The Other In Order To Make The Machine WorkComment
DANNIEBOY61
Yes you have to do a Clear+3-On Machine ,
Select 2 - Start
Off and On with Clear+3 again
Select 3 - Start
Off and On with 4+9
(wait till the machine read all then you just press Start )
Completed then Off
On + 947 - Initializes
Off and On with 0+8 - 690 - 2 - Enter
Done ( pull your thumbdrive out )Comment
