Toshiba Estudio 5540 Cleaning unit is Full of toner
  • aligis
    • Jul 2010
    • 56
    HI every one, we have 2 E-studio c5540 one of them is throwing out the Yellow toner and fillup the cleaning unit... and creating Yellow bands on page... any idea thanks...
  • arnh79
    • 469
    Re: Toshiba Estudio 5540 Cleaning unit is Full of toner
    I hope you find a solution, because I have an e5520c in my territory that does the same thing. I've replaced numerous parts and nothing works. Every few months I have to go over and vacuum out the cleaner assembly.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • stockman123
      • 128
      Check the yellow corona to see if it let loose the block in the rear sometimes breaks over time which causes this problem
      • canonbundy
        • Jun 2012
        • 607
        Check PM, replace Drum, DCB & Grid, more than likely o/due also you may need to replace the Developer - remove Drum Unit & check Mag Roller for banding on it also - not a cheap job.
        • Luther
          • May 2006
          • 682
          This still happens on the 40 series, the toner has dv in it and is supposed to replenish the dv,(shouldnt have to change dv) there was a mod to the seal where the dv meets the toner bottle it was made wider so it could add more dv/toner mix...did a bunch of them and so far so good, but time will tell..changing the developer will help but it may happen again...and like the previous post said its not cheap
          • aligis
            • Jul 2010
            • 56
            developer unit is ok , there was toner in chargeing unit ,, well cleaning unit was blocked at the exitance.... it was like someone has placed a brick wall....till now its working fine,, thanks for all
