Alternate sep. roller/sleeve for e452 RADF ???
  • CCS
    • 266
    I have 452/453's out that customers are scanning 5k+ a week.
    So every 2-3 weeks the RADF sep. is starting to get slick and cause jams/e712's.
    I'm trying to source a better roller or at least a sleeve I can use that will be more cost friendly to replace so often.
    I've looked through rollers and sleeves that I have used over the past 25-years with no luck finding an alternate, the sleeve is so thin that anything I try that is fatter just flat-spots after 2 or 3k.
    I can put 3 new sep. rollers in before it needs the whole kit, as the P-up and Feed are a fat tire and last great you know.
    Anyone know of an alternate sep. roller or sleeve that works ?
  • b1406
    • May 2008
    • 51
    Re: Alternate sep. roller/sleeve for e452 RADF ???
    I had to replace a separation roller on toshiba estudio 352, I did not had that roller at the time so I had to fix the machine at least for 2 days
    until I had the original sep. roller.So I tried a samsung ml-1710 cheap paper feed tire replaced only the tire and the machine works fine no jamming not a single problem with RADF for more than 20K consider that the costumer make 700-900 scanning a day,I think you should try it.
    Hope it helps
    • CCS
      • 266
      I will give it a try, thanks.
      • excanonguy
        • Jun 2008
        • 173
        try using 6le49877000 its a newer style green opaque roller that's used in the e756 etc, we have been putting them in the older feeders and they have really improved the performance of the feeders.
